Build two A frame stands with pivots so the wing can rotate.
Turned the wing, bottom side up. Marked the trim line along the fabric perimeter and cut the fabric to the final size. Glued down the fabric around the leading edge, trailing edge, tip bow and the root rib.
The rest of the afternoon was used to iron out the wrinkles and puckers in the bond area.
