Today I attached the horizontal and vertical stabilizers, hopefully for the final time. All attachment bolts were torqued to the proper value. Then I attached the rudder and rigger the rudder cables between the rudder and rudder pedals. Attach links were fabricate for this. The links were bolted and safetied to the rudder pedals and the rudder cables.
An exit hole for the rudder Nav/Strope light was drilled in the rear bulkhead.
Rudder stop was drilled to rudder hinge brakets and installed.
