I spent a bit more time at the hangar considering static, pitot and AOA tubing routing then took wire and electrical supplies home to work in the warm. I wired a test harness for the trim servos and both checked out proper operation of the servo and indicator. The servos are now ready to install in the airplane. I also assembled the wiring harness for the nav and strobe lights in the wingtips and tail.
