Brief Description: Tank angles and nose reinforcements
A short day today. Riveted the tank attach angles and reinforcement plates to the innermost ribs of each tank and also riveted the reinforcement plate to the outer rib on each tank. It turns out I had only mixed enough sealant to put down the final sealant fillets along the rib to skin joint for outer ribs on one tank. The other will have to wait for tomorrow. Also put sealant on the connections to the inner fuel sender plates.
