The Christen breather "T" installation was completed and tubing cut and run from engine to "T" and "T" to oil tank.
The oil temperature probe was installed and wired.
The oil and fuel pressure sensors were installed and wired.
A hole was cut in the firewall for the electronic ignition wiring. Hole was deburred and dressed and a snap bushing installed. E/I wiring harness routing was started.
Began planning on manifold pressure sensors. There are two, one for the Dynon as a gague reading and the other to the electronic ignition. Need to decide whether to put them on the engine or cockpit side of the firewall.
