Today is my Dad's 90th Birthday!! Happy Birthday Dad!!!
Today I continued installation of the Christen inverted oil system. The oil valve was mounted to the fuselage after fabricating a doubler, drilling it to the firewall, drilling for platenuts, deburring, dimpling and countersinkin and riveting the doubler.
The oil sump, return and strainer fittings were all installed after removing the respective plugs.
A doubler the fof the breather "T" fitting was fabricated and drilled, platenuts drilled, holes deburre and dimpled or countersunk as required.
