The oil quick drain was installed after I finally figured out what fittings I needed. I used a 90 degree elbow in the installation which should allow me to drain the oil without removing the cowling. Engine was then serviced with 6 quarts of Aeroshell 100 mineral oil.
The eyeball vents I ordered from Affordable Panels arrived and these were installed. Vents hoses wre attached. This then allowed me to replace the outer sections of the panel which had been removed for vent installation.
The pilot seat back was reinstalled and seat cushions put in place.
With the panel back in place the COM radio and intercom modules were reinstalled. Then the last network cable was attached to the network hub and the EFIS screen was installed,completing the panel.
The rivets for the bulkhead cap strip were completed.
