Brief Description: Left wheel fairing, lower intersection fairings
Today I drilled platenuts to the left wheel fairing, countesunk holes as needed, and riveted platenuts to the fairing. The outside attach bracket was riveted to the aft fairing. The fairing was mounted on the left grear leg and then the leg fairing was measured to make sure it was properly aligned.
With both leg fairings confirmed to be aligned propery I fitted the lower intesection fairings to the leg/wheel fairings. These were trimmed as needed, drilled for a few temoprary clecos and then were adhered to the front and aft wheel fairing pieces using a flox epoxy paste.
