Replaced the valve stem valve in the right tire. Hoefully this will correct the slow leak it has.
Removed each wheel and removed and greased the wheel bearings. Bearings, packing and retainer replaced and wheels replaced on axles.
Mounted the right wheel fairing to the right gear leg using final hardware. Confirmed alignment of leg fairing. Di trial fit of lower intersection fairing.
