Bills RV-7 Build Site
Date:  1-6-2016
Number of Hours:  3.00
Brief Description:  Gear dampeners, Flap hinge wires
The gear leg dampeners were cut to length and attached using Gorilla Tape. I had to cut them a little shorter than planned since my hinges are further from the edge than spec'ed but hopefully they will do the job.
Cut center 3 eyelets from the flap hinges ( one on wing, 2 on flap) to proved easier way to insert flap hinge pins. Pins were then cut to length and bent so they can be safety wired.
Gear leg dampener positioned
Taped to leg
Taped to leg
Flap hinge pins
Flap hinge pins
