Bills RV-7 Build Site
Date:  1-5-2016
Number of Hours:  5.00
Brief Description:  Battery wire, wingtip wiring
Installed 3 remaining bolts at the bottom of the forward main bulkhead. I missed these earlier as they are used to attach the landing gear bracket on the tri-gear configuration, but there were no instructions to go ahead and install them if building a taildragger. The bottom ones were a bit inconvenient to get to but I taped my washer wrence to a paint stick and an open end wrench to a plastic knife and managed to get the waher and nut on the bolt end between the bulkheads.
I fabricated the positive wire for the battery and installed it, connecting one end to the master solenoid. The battery end remains unatached for now.
Installed connectors to the Nav/Strobe and Landing/Taxi ligh wires at the end of the wing.
Battery wire
Battery wire
Main bulkhead bolts
Main bulkhead bolts
Wing tip wiring
Wing tip wiring
