The left wing tip was touched up with light sanding after mounting the Nav/Strobe light.
The landing/taxi light hole in the left wing tip was sanded to shape using a single sheet of sandpaper drawn through the gap between the light and the wingtip. This was pretty time consuming and tedious but yeilds a nice result.
The Nav/Strobe fillet was sanded to shape on the right wing tip.
The landing/taxi light hole was sanded to shape as above.
The landing light lense was cut in half and then the lense for the right tip was marked, trimmed and sanded to proper fit. This is a plexiglass part.
Connectors were crimped to the landing/taxi light wires.
