I did a bit more touch up sanding around the taxi/landing lights and then prepped them to have to pivot plates attached with adhesive. These were attached using a flox mixture of epoxy, and the tips were placed in my Toyota curing oven to harden
Next I got out one of the wheel pants and fitted the front and rear pieces and cut out the whell opening. The outside attach brackets were bolted to the axle nuts and an initial fitting of the rear section was made to the left wheel. This required trimming away a slot for the gear leg to protrude from.
