Bills RV-7 Build Site
Date:  5-28-2014
Number of Hours:  0.50
Brief Description:  Tank test
Right tank held pressure through night, so it should be fine. The left tank, which had two leaks coming from the raer baffle, were treated yesterday as follows:
1. Tank left in sun to heat.
2. Once heated, fuel line, vent and drain fittings were taped to close.
3. Tank brought into hangar and Locktite #290 applied to leak area.
4. All rivets in leak area squeezed a bit tighter.
Next day test was successful, so some of the above seemd to work!!
Beginning of day
Beginning of day
End of day
End of day
