Cut all elevator stiffeners to length using snips, cut trailing edge taper using band saw, then rounded corners and smoothed edges using Scotch-Brite wheels on the grinder. Match drilled stiffeners to the top and bottom skins of the right elevator. Not a lot to talk about or show in pictures but a good night's work.
