Brief Description: Flap Position Sensor and wiring
Fabricated a mounting bracket for the Flap Position Sensor. Used it as an opportunity to learn how to use the sheet metal bending brake. Wired the position sensor using shielded wire, so I also learned how to solder a conductor to the shield pigtail and used the same dsub connector technique to wire up the sensor and flap motor power wires
