Brief Description: R wing, tip marked and drilled, tank finalized
in preparation of the left wing going to paint this week I worked through a list I made up to complete work on this wing with 6 tasks starting with finalizing the wing tank - closing up the tank hole, making up the sender and cover plate assembly, safteying and sealing then making up the vent line coil and installing it all in place on the wing, then sealing up with proseal and finally pressure testing - all as per the right wing, already completed.
I also worked some more on the now aligned right wing tip and final drilled (this time for #6 screws), deburring, and dimpling the wing tip end and marked and punched the wing tip for match drilling and fitting.
