Brief Description: make-up, fitting and glueing of strips to tips
Reinforcing strips continued, made up the remaining strips and redid some of the first cut because they were either drilled wrong or too narrow. Continued the process of fitting trimming, fitting, match-drilling and bonding strips in place.
Some more fitting and adjustment of holes by reaming and countersinking the fitting holes on the tip to match the wing holes already dimpled and finalized = to get as perfect a fit as I got in the first fittings.
