STANLEY'S WEB SITE
Date:  10-20-2009
Number of Hours:  2.50
Manual Reference:  KA-1
Brief Description:  Fuel System
Drilled hole in right wing tank for fuel sender, cleaned tank of metal particles. Check fuel level sender with OHM meter to be sure it worked properly, then installed fuel sender.
Partially fitted angle to No. 1 rib for top I/B skin. This doesn’t fit too well and will need to do a lot more work to get the angle correct.
Fuel Sender in Both Tanks
