STANLEY'S WEB SITE
Date:  10-18-2009
Number of Hours:  2.50
Manual Reference:  KA-1
Brief Description:  Fuel Tanks Sender
Deburred, cleaned and primed vertical ā€œLā€ support channels for rear tank support bracket. Then riveted ā€œLā€ support to rear channel.
Cut 59 mm hole in fuel tank per specs. Cleaned tank of metal particles. Check fuel level sender with OHM meter to be sure it worked properly, then installed fuel sender.
