ELT Antenna Connection / Firewall Fuel Fittings Made up the coaxial cable to go from the ELT antenna to the ELT unit. Also fabricated another firewall fitting for the fuel line. Not sure which on I will use at this point. Make a bracket for the line from the AndAir valve in the center console to the fuel filter on the electric fuel pump.
