Worked on the layout for the fuel line from the AndAir selector on the center console, to the fuel filter and electric fuel, to the fuel firewall fitting to the mechanical fuel pump. In the process, discovered that the mechanical fuel pump on the engine was install upside down. Removed the mechanical fuel pump and rearranged the pump so it would fit properly.
