CHUCK'S WEB SITE
Date:  9-20-2022
Number of Hours:  1.70
Manual Reference:  SNB-T14
Brief Description:  Installing Vertical Tail Fiberglass Tip
Positioned SNB-T14-04 tail tip rib to line up with rudder when rudder was centered for neutral position. Taped into position and drilled the first hole to allow a cleco to hold one side.
Verified alignment was maintained, and drilled second hole to fix alignment of the rib to the rudder, then drilled the third hole.
Updrilled from #40 to #30, deburred, and riveted SNB-T14-04 rib into place.
Layed out intitial cut lines on fiberglass tail tip and cut excees material off the tip. First test fit shows more trimming required to move tip trailing edge into alignment with the rudder trailing edge.
Initial hole layout for SNB-T14-04  fiberglass tip rib.
Layout of intial fiberglass tip cut lines, keeping perpendiculat to the trailing edge.
Initial cut's fit to the vertical tail and rudder trailing edge.  More trimming required.
