CHUCK'S WEB SITE
Date:  9-25-2022
Number of Hours:  2.90
Manual Reference:  SNB-T14
Brief Description:  Installing Vertical Tail Fiberglass Tip Continued
Continued fitting/installing the vertical tail fiberglass tip.
Trimmed slight more than 1/8" of the bottom edges of the tip to bring the trailing edges of the tip and the rudder into alignment.
Once aligned properly, I drilled all #40 pilot holes on the vertical stabilizer portion, and clecoed this in place. I then removed the tip and layed out the 6 pilot holes on the trailing section of the tip which will be used to drill the holes into the trailing rib.
I then re-installed the tip and used the trailing section pilot holes to drill the #40 holes into the trailing rib, then fully clecoed the tip into position.
Next, I removed silver #40 clecoes a few at a tiem, updrilled the #40 holes to #30 size, then reclecoed with copper clecoes.
Once updrilling was completed, I dissassembled everything, deburred, and re-assembled with copper clecoes.
Final reveted the full tip into position with CCP-42 & CCP-44 rivets as specified by the plans.
Tail section completed.
Vertical tail tip fully clecoed into position with #40 silver clecoes.
Up-drilling from #40 to #30 holes.
Final tail assembly, complete with fiberglass tips installed.
