Installed the two fiberglass tail tips on the horizontal stabilizrer.
Mounted both SNB-T14-04 tip ribs on the each end of the horizontal stabilizer.
Layed out initial cut lines on fiberglass horizontal tail tips to start fitting/trimming process, ensuring long lines are drawn perpendicular to the trailing edge. Made multiple install/fit passes to get the length right so tip trailing edge lined up with elevator trailing edge. After each fitting, a new tape line was layed out, and the material removed up to the edge of the tape, then fit checked again.
Installing the tail tip aft section rib on the end of the Horizontal stabilizer.
Marking intial trim cuts on the horizontal tail tip, ensuring long cuts are perpendicular to aft edge.
After many reiterations of fitting, trimming, and refitting, length and fit are good.
