Brief Description: Final Fitting And Mounting Pivot Blocks.
SNB-C01.
Drilled the second 3/16" bolt hole in the pivot block from underneath through the bracket plates. Once this was bolted and tightened, it put too much clamping pressure on the rudder pedal tubes. The pivot blocks were removed and placed in a vice and the holes reamed larger with the small brake cylinder hone. This took several iterations to get what I think is the right pressure on the tubes to allow free and smooth movement.
Left side rudder pedal pivot block fit and mounted.
Right side rudder pedal pivot block fit and mounted.
