Tonight we installed the Stailator and the Bracket that holds the Elevator trim servo. I used clear RTV to hold tha washers on to the servo bracket instead of superglue. The RTV took longer to dry, However, it seemed like it didnt make nearly as muich of a mess as Super glue would have. The rudder hinge bolts and the stabilator attachment bolts still need to be final tightened. The counter balance arm has the bolts installed but it does not have washers or nuts installed.
