Craigs RV-8 Web Site
Date:  1-26-2012
Number of Hours:  1.00
Manual Reference:  8s8-1r1 12/02/08
Brief Description:  Flap Motor
Page 8-59
Final Drilled the 1/4 inch holes in the A-406-1 bracket
Attached the A-406-1 bracket outboard to the F-807A-L-1 bulkhead
Final drilled 1/4" the holes in the three Clovis brackets on the WD-806 flap actuator weldment
Installed the WD-806 flap actuator weldment to the fuselage
Drilled hole in the flap motor for safety wire
Attached the flap motor to the A-406-1 bracket outboard and the WD-806 flap motor weldment
