Craigs RV-8 Web Site
Date:  1-28-2012
Number of Hours:  3.00
Brief Description:  Rear seat rudder pedals
Built the rear seat pushrods per drawing OP 5 pushrod assembly detail.
Removed two of the AN3 bolts used to attach the F-8118 brackets.
Match drilled and installed the F-8118 idler brackets to the aft side of the F-802H
Installed the WD-830 idler arms
Drew a reference line on the top surface of the F-8117 guide bracket flanges
Positioned the F-8117 brackets in position and drilled a # 20 hole through the existing mid-cabin cover attach hole
Installed a screw through the bracket and drilled the holes through the F-880B seat ramp ribs using the pre-punched holes in the brackets as guides
Drilled a #20 hole through the guide brackets into the F-804 bulkhead
Deburred and primed all parts.
Installed brackets and Installed the WD-829 pushrod assemblies
Rear rudder pedal
Rear rudder pedal
Read rudder pedal support
rear rudder pedal complete
