Brief Description: Rear Spar Assembly Elevator Hinge Brackets
Clecoed the HS-412 and HS413 elevator hinge brackets to the rear spar and matched drilled them Also clamped the HS-411PP brackets (A&B) around the VA-146 bearing then clecoed that to the spar. Need to buy #21 and #12 drill bits to go further so we stopped for the night.
