Craigs RV-8 Web Site
Date:  3-8-2018
Number of Hours:  5.00
Manual Reference:  11/29/12
Brief Description:  Installing the Inlet Ducts
I used some foam and clay to make the shape I wanted to close off the inlet ducts.. I covererd that with a layer of saran wrap so that I could remove the clay and foam. I then layed up 2 layers of fiberglass (West Systems). Once that set up I separated it, removed the clay and foam, made up some epoxy and flox and then fastened it back in place with clecos until the flox set up.
Foam Plug
Foam Plug
