Craigs RV-8 Web Site
Date:  3-7-2018
Number of Hours:  3.00
Manual Reference:  11/29/12
Brief Description:  Installing the Inlet Ducts
Page 12-5
Fitted the ducts to cowl, trimmed and sanded as necessary for a good fit. Drilled and clecoed them in place.
Cleaned the area to be bonded by sanding with a coarse 60 grit paper.
Drilled holes for clecos, Mixed up some west systems epoxy and flox, mounted the inlet ducts.
I may have done something wrong when I fitted the baffle or positioned the ducts. The ducts will create a tunnel which will defeat the whole purpose of the baffling. I will need to make up a plug and close at least one side off tomorrow. The Baffle will have to be refined around the inlet ducts as well.
