Clecoed the CB-1007B aft right support bracket to the CB-707A Right aft case baffle and final drilled #30 the holes common between the parts. Clecoed the CB708A cylinder 3 baffle to the CB707A right aft case baffle and final drilled #30 the common holes. Clecoed the CB-1003C doubler plates and CB-1008B stiffener to the CB-708A cylinder 3 baffle. Clecoed the CB-700E doubler plate to the CB-707A right case baffle. Final drilled all of the holes common between the stiffener and the cylinder 3 baffle Final drilled #40 the rivet holes common between the doubler plate and the right case baffle. Final drill #40 the holes common between the remaining doubler plates and the cylinder 3 baffle. Created a cutout for the ignition wires . Disassembled, deburred, dimpled and primed all of the parts. Dimpled the rivet holes in the CB-1003C doubler plates and CB-707E doubler plates and the corrisponding holes in the CB-708A Cylinder 3 baffle, Riveted the CB-1007B aft right support bracket to the CB-707A Right case baffle. Riveted the CB-1008B stiffener to the CB-708A cylinder 3 baffle Riveted the CB-1003C doubler plates to the CB-708A cylinder 3 baffle Riveted the CB-707E doubler plate to the CB707A right aft case baffle Riveted the CB-708A cylinder 3 baffle to the CB-707A right case baffle.
