Brief Description: Fitting the C-801 plexiglas bubble
page 9-3 Modified a #27 drillbit to drill plexiglas and drilled all of the holes in the canopy to #27. Drilled the holes in the canopy frame to #30 Marked and trimmed the sides of the canopy to match the bottom of the upper cnopy frame tube. Sanded all edges with 120 grit paper mounted to a dual action palm sander. Debured all holes
Drilling the cnopy to #27
cutting excess plexiglas with the dremel tool and a rotary bit
