Page 8-66 Modified the aft end of the two F-858-1 shoulder harness anchors Clecoed the anchors in place and final drilled #30 the common holes Final drilled #40 the 3/32 holes common between the F-825-1 Aft top skin and F-807B-1 F-808B-1 F-809B-1 and F-810A-1 bulkheads. Final drilled #40 the 3/32 holes common between the F-825-1 aft upper skin and the canopy rail receptacle Unclecoed and removed the F-858-1 shoulder harness anchors and the top skin Final drilled #40 the 3/32 holes along the edge of the upper skin common with the longerons
