Final Drilled the 1/4 inch holes in the A-406-1 bracket Attached the A-406-1 bracket outboard to the F-807A-L-1 bulkhead Final drilled 1/4" the holes in the three Clovis brackets on the WD-806 flap actuator weldment Installed the WD-806 flap actuator weldment to the fuselage Drilled hole in the flap motor for safety wire Attached the flap motor to the A-406-1 bracket outboard and the WD-806 flap motor weldment
