Final drilled #12 the outboard two 1/8 holes in the end plate of the WD-817 rudder slide bar Final drilled #12 the two 1/8 holes in the flange of the WD-818 rudder socket. Inserted the tube of the WD-817 rudder slide bar fully into the WD-818 rudder socket and temporarily bolted them in place on the forward cockpit floor and firewall assembly Match drill #12 one of the 1/8 holes in the WD-818 rudder socket into one wall of the WD-817 rudder slide bar. Temporarily inserted AN3 bolt in the hole and match drilled #12 the hole. Deburred all of the drilled holes Final drilled 1/4" the hole in the WD-816 rudder slide that receives the F-8103E lock pin Put the F-807 slide collar and WD-816 rudder slide in place on the WD-817 rudder slide bar. Bolted the WD-818 rudder socket to the WD-817 rudder slide bar Drilled a #30 hole in the top of the F-8107 slide collar and WD-817 rudder slide bar. Installed the blind rivet. Placed the WD-804-L and -R rudder pedals on the WD-816 rudder slide. Placed the F-874 rudder pedal slide block on the outboard end of the WD-816 rudder slide. Page 8-61 Match drilled #12 the hole in the forward side of the F-874 rudder pedal slide blocks into one wall of the WD-816 rudder slide tube. Match drilled the other side of the tube #12 Deburred the #12 holes Applied a thin coating of grease to the interior of the tube on the WD-804-L and -R rudder pedals and the outside surface of the tube on the WD-816 rudder slide. Re-installed the left and right rudder pedals on the rudder slide.
Bolting the slide bar into place for match drilling
