Craigs RV-8 Web Site
Date:  10-22-2010
Number of Hours:  3.00
Manual Reference:  8s8-1r1 12/02/2008
Brief Description:  Drilling fuselage skins
Page 8-28
Aligned the outboard edge of the F-816- R-1 cockpit rail flush with the outer suffice of the F-823-1 mid side skins. Clamped the cockpit rail into position
Match drilled #40 the F-887-R-1 upper longerons using the 3/32 holes in the cockpit rail.
Final drill #40 the 3/32 holes common between the F-816--L-1 R-1 cockpit rails and the top flanges of the F-804C-L-1 and R-1 center section fwd bulkheads and the F-804C-AL and AR center section aft bulkheads
Wrapped cargo straps around the fuselage to align the landing gear box flush with the vertex of the longerons.
Match drilled #30 the five holes at the top of the F-802C-L-1 and R-1 landing gear box web to the F-877-L-1 and R-1 upper longhorns
Clecoed the F-817-L-1 seat back support plate in place on the F-806A-L-1 left fuselage bulkhead and F-805-L-1 left fuselage bulkhead
Clecoed the F-817-R-1 seat back support plate in place on the F-806A-R-1 left fuselage bulkhead and F-805-R-1 left fuselage bulkhead
Final drilled #30 the 1/8 holes common between the F-817-L-1 and R-1 seat back support plates and the F-806A-1 L-1 and R-1 and F-805-L-1 and R-1
left and right fuselage side bulkheads.
Separated the two F-856-1 spacers from each other , smoothed and deburred the edges
Clecoed the F-856-1 spacers in place on the bottom of the F-816-L-1 and R-1 cockpit rails
Clecoed the WD-808 front seatback support in place between the F-817-L-1 and R-1 seatback support plates
Drilling the right cockpit rail
Drilling the Landing Gear towers
Seatback support clecoed
