Craigs RV-8 Web Site
Date:  10-21-2010
Number of Hours:  1.50
Manual Reference:  8s8-1r1 12/02/08
Brief Description:  Drilling fuselage skins
page 8-27
Placed a cleco in every hole in the upper portion of the F-804N-1 L and R bulkhead caps
Placed a cleco in every 3/32 hole in the F-823-1 common with the F-887-L and R-1 upper longerons to ensure the the skins are flush against the sides of the 887 upper longerons
Page 8-28
Aligned the outboard edge of the F-816-L-1 cockpit rail flush with the outer surface of the F-823-1 mid side skin. Clamped the cockpit rail into position.
Match drilled #40 the F-887-L-1 upper longeron using the 3/32 holes in te F-816-L-cockpit rails.
Heavey clamping frought the skin flush with the outer edge of the cockpit rail
Drilling the left longeron
complete
complete
