Page 8-12 Made up the F806E spacers clecoed the F-806C-1 and D-1 attach bars to the F8-6B-1 rear spar attach bulkhead Clecoed the seat belt attach lugs and the F-806F-L-1 and R- 1 gussets to the F-806B-1 bulkhead Match drilled the bolt holes at the outboard end of F-806B-1 Final drilled all of the 1/8 holes common between the parts Made the F-80=5D-L & R brackets Clecoed the F814CR-1 inboard seat rib angle and the F-814J fwd seat belt / Vent anchor top the 814G-1 seat belt anchor and clecoed the assembly to the F-814A-R-1 rib assembly Clecoed the right F-805D-R brackets to teh F-8145-R-1 fwd seat rib assembly. Match drilled all of the 1/8 holes #30 repeated the steps for the left fwd inboard seat rib assembly
