Craigs RV-8 Web Site
Date:  7-26-2010
Number of Hours:  5.00
Manual Reference:  8s8-1r1 12/2/08
Brief Description:  Seat Rib Subassembly
Page 8-13
trimmed the fwd corner of the bottom flange of the aft outboard seat rib
cleco'ed the ribs to the rear spar attach bulkhead.
fluted the left center bottom skin to match the seat ribs
clecoed the skin to the assembly and final drilled the holes to #40
Deburred and primed all of the parts
Began riveting the assembly together using the rivet callouts
Installed the brackets for the aileron trim. No need to cut the ribs. they have the corner holes and cut out already fabricated. Cleco'ed the template on and match drill the holes. I chose not to use pop rivets so I dimpled and installed the brackets with flush rivets
Seat rib subassembly clecoed together
fluting the bottom skin
Riveting the sub assembly together
