BRAD'S WEB SITE
Date:  2-11-2018
Number of Hours:  1.50
Brief Description:  Wing root ribs
Drilled and cleco'd the wing root ribs (2) which add a foot or so of wing in between the flaps and the fuselage. A little less than an inch has to be cut from the end of the lower stiffener so that the rib will fit into place. Had to drill out about 6 rivets so that the aluminum pre-bent wing skin would slide up underneath the bottom panel. Drilled and cleco'd both sides so that it would be solid in order to guage a starting point for the flap/aileron alignment. The kit also comes with a jig of the proper shape of the upper part of the wing. Root ribs, flpas, ailerons were all checked and looked good.
mark to cut stiffener
root skin slides under existing
contour checker
contour checker
