Brief Description: Lexan test fit for kinks and dimples
View from the top of the skylight support. Most have separated into 3 panes due to the curve in the roof form. I'm going to try to get away with one piece of Lexan. I think I have a shot. Will weld about 4 tabs each down the center longitundenal tubing to attach the Lexan in the middle and will be attached on 3 inch centers all the way around. I clamped it down and a single sheet conforms "mostly." Will need a little bigger sheet to cut to size and clamp on all 4 sides to know for sure. This piece was a few inches short.
