Brief Description: Brennan's Door is hung and rear window cut
Brennan cut out the 4 strips for the passenger side upper window and drilled and Cleco'd them in. He still needs to cut the upper glass and cut the mouse door. Both Pilot and co-pilot side doors and upper windows function. Need to look into the door latch pin alignment. You have to pull up on the doors and force the pin to close to latch door. I'm not going to try to tweak anything though until the weight of the wings are on the plane. It may change with that?? Matched the pilot side rear window with the one cut out in the cargo door. My first oops. I didn't account for the alignment of the lower side with the door bottom and I'm an inch or so short. Not sure what I'll do about that. May change it later.
