Installed engine with help of my son Kevin using the engine Vans engine DWG's, manuals and the help of my HB heavy lift, we put the top 2 Lord rubber mounts and 2 steel tubes and 2 bolts, Washers nuts per DWG 46A in first Then the bottom rubber mounts 2 steel tubes, bolts/washers/nuts in. We had to tighten the top bolts in to get the bottom bolts in but not a big problem. When all the parts were in in tightened all the bolts to the place they would not tighten any more as they bottom out on the tubes which is correct. We also had to remove some nuts and add washers so the cotter pins would fit.
