after priming revited W-707G & W707D to W-707W to W-707A R Fabricated W-707E and W707F reinforcement plates then drilled toRW rear spar Cut aileron push rod hole per manual with small holes then with a unibit. Got the holes big enough so i could file and sand the rest on the hole out. Then sanded the W-707E
