I had left cleco's in the front skin of the rudder with out riveting them to let the bend of the skin so it would set and form better which seemed to work well. Took every other cleco out then drilled to #30 bit then riveted them with AD-41-ABS Rivets per drawing. Re measured the 3 Rod Bearings for distance,
R-901 R/L DWG 7 left side view measure top center bolt hole rod bearing to front spar 51/64 " middle bearing 59/64" Bottom bearing 1 1/16"
