Brief Description: Brakes drilling the gear legs for cotter pins
Drilled the cotter pin holes per C2 and brake kit manual after adjusting tourque then installed the cotter pins through the axel nut and the gear leg. Then lifted the fuselage off the work benches with my Big Red HF engine lift and now it is on 3 legs.
