Started work on elevators to aligned togather for fitting to HS.aligned & Adjusted front rod bearings per DWG 27A to 26/32" from spar to each center of bearings and set the lock nuts, measured for triming top and bottom HS-skin 601PP and HS-515 tip Per DWG-3
