Brief Description: Started working on the baggage area
DWG-21: Work on F-706A-L and F-706A-R which togather is the F-708 Bulk head asssembly. DWG: Set up F-751 lower baggage bulk head to the F-708 bulk head marked and drilled after clamping. Using the pre drilled holes on the bottom(8) and the holes(8) and the(8 side holes
